Wow. Just when you think you've seen everything.
Yes that is a 69 or earlier k-frame. That probably is the factory ebody/70-72 bbody sway bar since the width look to fit the Ebody/70-72 bbody LCA's.
You can buy new reproduction sway bar bushing U-shaped brackets.
