Since the brake light "Feed" circuit travels through the "Hazard/Flasher" wiring of your particular turn signal switch, there times that the contacts have overheated and failed, thus not able to complete the "Stop" circuit. Start by pinning out at terminals of the T/S hard shell connector to verify current flow. This is of course a battery "Hot", not key "On" circuit.
