Sorry , modded my post.
The pump shooter cams are yellow , just wondering if any of you guys change the cams out before you fit the carb , just seems to flood the motor with these cams , i realise the shooters may need changing out but just asking if this is a common problem with these 3 circuit carbs out the box?
Well my motor is tiny compared to yours,but I had to move down to 28's or 25's on the shooters and the yellow cam iam still trying to figure out how to move it to the 2 position.I think there is a brown cam that comes on later.
