I would think the milling solution on a solid shaft would be pretty straight forward and easy, just be sure you have a radius cut on the transition, rather then a corner, if it were mine, just a matter of set-up in the mill. twocents
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
