Well, if you are using a front disc, rear drum setup, the car needs an actual "proportioning" valve. The distribution" block has no proportioning in it.
Secondly, did the pedal return to the top of its range of travel before? I had a 72 Duster with a sticky brake and clutch pedal. That turned out to be due to rusty scale on the swivels where the pedals swing.
