I bought a set of 1971 fenders from AMD, main issue was with the passenger side fender, the gap to the door was uneven narrow at the top and bottom and wide in the middle, no way to adjust it out, put not that noticeable once everything was painted, but really noticeable when the jams are painted and the door and fender are in primer. Also, one of the headlight bucket weld nuts was on the front side of the fender and should have been on the engine side, easy fix to move it to the engine side. They will need to be skim coated. Drivers side was fine, no issues there. Overall, I would use them again.
