it doesn't set high at all, there is only 18-1/2" between the rails. and the huge dana takes up all of that
Have you actually had it on the ground with the back tires yet? I'd like to see a pic. 18-1/2" apart? Are you planning on running John Force's Funny Car slicks?
well yes it has 17x33s on it. I can just about set it on the ground with the shock adjustments.
