Did a compression check on a 440 I just bought. It supposedly has 10.1 compression pistons 906 heads that have been milled 30 and the block has been zero decked. The cylinders are showing about 250 psi average.Not complaining but seems high to me. I think it has higher compression than 10.1. What do you all think? Thanks.
