Yes. All monitors need to get set after erasing a code. Basically, you need to run through every possible engine load situation for the computer to say 'ok, we're good now.'
Part throttle cruise downhill, uphill, flat ground, WOT hot, cold, stop n go traffic, closed throttle coasting... 500 miles of highway alone won't cut it.
**Photobucket sucks**
