If your car is an original v8 car, then you will need 383/440 motor mounts and brackets. They are pretty common as 1966-1972 d/c-body car mounts are th same and it will bolt right in. You will also need a transmission for a big block as the small block ones have a diffrent bolt pattern on the bellhousing.
