With a big HEMI you are going to murder 27" tires on the street with any gear ratio. A gear set numerically higher than what you currently have will most likely make driving the car exponentially more exciting.
What kind of tire is on the car?
It seems like quite a few people have been surprised by similar ET's when they went up or down in rear end ratio either way.
