I needed a cup type so i bought the one trick flow makes... we will se how it works!!!
if any one needs to borrow it when im finished just let me know!!!
I prefer to use a ball/ball type rod for that measurment as it's pretty easy to hold it centered on the adjuster ball for the measurment & you need to measure the length from the bottom of the cup to the ball tip of the pushrod...
