If have a couple comments/thoughts:
1) Did anyone sonic check that block? at 4.100 you may get a surprise. You definately ( if machinist didnt already, and I HOPE he did)will need to know what the cylinder thickness is before anything. What are the sonic check numbers, especially the major thrusts?
2) You seem to be questioning your machinsts decisions. If you trust him, then go with his suggestions, but again, you seem to have some doubt?
3) You made it through the hurricane, so you can do anything. Keep plugging away, dont stop now.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
