hi
im at my wits end here
all was ok,
i went on an hour trip all was fine,
left to head home and
-Starts off in 2nd or 3rd,
You can manually shift into first
-doesn’t go into OD or lockup
-OD light won’t come on or off
-no cruise control
-gear indicator only lights when in neutral or park, unless key is in accessory position then all light
Replaced:
Pr lockup solenoids “solenoid pack” 52118500AB
-governor solenoid 4617210
-prindle/neutral safety switch 56045489AC
-transducer solenoid 56028196AD
-adjusted shift cable
-adjusted safety switch
-checked and cleaned all grounds and grounded PCM
-left both batteries disconnected overnight to clear codes
-removed fuse block under hood and cleaned all connections,
-replaced the TCM , it was flashed to the vehicle
its not throwing any codes
any new ideas?
