I could see a less than perfect size booster/MC causing a problem but from the descrip it sounds like there is a mechanical failure/issue somewhere. A suggestion since the booster (even if undersized) & the MC are good/bled is rehook the MC line to the front discs next to the firewall port only & bleed it out & work with them first & see if I can get it to straighten up
