Originally Posted By sshemi
Rods have plenty of clearence as the rod bore is on the bigger side. Actually a bit too big.
Ill check main clearence with plasti gauge. I have never used it but i feel on this i need to.
Or just spend the $400 the machine shop wants to correct it all.
That includes cylinder hone also.
That'll be the best 400 dollars you can spend. The mains need a hone and the rods resized.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
