If you are talking the isolator that allows you to run the fuel pressure gauge in the cockpit my suggestion is to mount in the GARBAGE CAN! Those things are VERY slow to react and if you REALLY need to know your fuel pressure are worthless. Just my
I happen to like mine and I checked it against a gauge,
its within a 1/4 psi
