It seems to me that the last time I did this I used the .050 before/after max lift also. This time the instructions I was using recommended .010. As far as my saying I installed the cam 'straight up' perhaps my terminology leaves a bit to be desired. What I should have said was something like zero to zero, in other words I just lined up the marks, checked the degree wheel and got a value of 106'.
