If you had access to a lathe you can do your own. I did Itook a set of weld draglites and separated them at the weld and added a strip in the middle tig weld it up viola . Mine are 15x12 1/2 8 1/2 backspace.
I do have access to a lathe, but my current rims are 15x8 so I need to buy 15x12. Figured I may as well get the correct backspace when I order them. That is a good plan though. That would be interesting to try.
