Looking for pics on how you guys did your core/radiator support areas. Looking to redo mine with some moly tubing so I can move my radiator forward. I'll probably take my inner fenders out but use the stock steel outer fenders. Tubing sizes would be appreciated also. Does anyone make a bender for small tubing? 1/4, 1/2, 3/4, 1" tubing. I don't plan on using it much so I have a hard time buying a bigger set-up that will do 1 1/2 and up. Thanks, Clint
