Thank you for replies, I will check mine to see if it is tight to move back in to the correct length since it is too long according to biggE.
I will be installing the lock pin in the coupler for sure. Wouldn't want it to loosen up and be too long either then it won't be in the happy spot in the coupler like manual recommends.
