Dan Wersharr said had to change those bearings twice or more each season IIRC. They get play then knock the pads back and you lose your pedal. To run a fixed rear caliper, a floater is pretty much mandatory. Otherwise run the Wilwood D52 caliper or Dr Diff.
Mopar to the bone!!!
