Originally Posted By dogdays
IIRC the 4.80 with the 308 bearing and the 5.125 share common mounting bolt patterns, should be able to swap to get it to fit.
Also, NP435s have a 5.125" diameter.
R.
I think you can turn the OD of the 5.125 retainer down to 4.80 also.
Kevin
