Did anyone catch the comment about until this year it was a set amount of time after the last stage light and that drivers could hit the tree early to cut better lights??? Did the starter not have the switch then???
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
