Here's the dilemma ... you can blow all the air you want through there BUT the outside air will warm up faster than anything you store in the trailer will SO the warm, humid outside air will condense when it contacts any cold surface or item in your trailer. The additional airflow could cause more condensation than no airflow at all. Other than a heater in the trailer I think you're fighting a losing battle.
