I believe I have both the TRW and the Fed pump. Not sure which I installed in the car, but it came off of a 67 318 ( using big block brackets).. I have a pic of the pump on the motor( after I pulled the motor from the car) and it had the large vertical return line ( coming out of the top of the pump.
Just wondering if anyone is in the know on these??
