I'm getting ready to install 2"x3" frame connectors in my 65 Coronet and my question is how far should I slide the frame connectors into the rear longitudinals? I am also moving the springs inboard at the same time. Is it possible to incorporate the two together and also use the connectors as spring mounts??
