Am I correct thinking TDC @ 1 will have number 6 I&E rocking ? for ignition timing purpose ? being a slotted type in th RB mopars they can be either right on or 180 off, far as mechanical timing goes, however can certainly be ignition miss timing if rotor does not match number 1 on cap and then CCW firing order of 18436572
