Part of building power with exhaust manifolds is trying to keep the intake port velocity up without the benefit of exhaust scavanging.
The bigger the intake port, and valve, along with more low lift flow(which almost always means more flow in both directions), relative to the size of the motor, the harder it is to build velocity at moderate engine speeds.
To me that means that you'll want to make the motor as big as is practical to use the TF head with it's fantastic low lift flow and 2.19 valve in this type of application.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
