Hi all. I have a 71 Satellite with power disc/drum combo. Is there a more modern master cylinder that is a bolt in replacement for what I have? Original looks is of no concern. Aluminum and plastic would be just fine. I'm just tired of the leaky masters. The remans that I have used all leak from the get go and get worse over time. Anyone know an application that I can ask for at the part store that will bolt up and go?
Thanks in advance
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
