I'm hoping someone can run some compression ratio numbers for me. I'll supply the data and you do the math. I can't get the numbers to come up with what I think they should be.
Here goes: 4.0705 bore 3.313 stroke .055 gasket with 4.150 bore 67 cc chamber 110 cc 1/2 inch down fill Piston is .044 positive out of the bore
Run the numbers and see what you get.
Thanks in advance.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
