They were the ones that went through to the same passage as the air/fuel mixture screws. The passages were perpendicular to eachother, so the holes I am talking about were supposed to go far enough in to penetrate the a/f mixture passage, but when I looked in them, there was only a small hole there but I could see the angle of the drill. It just was not drilled through completely.
