IIRC, rear springs went from 2 1/2"x52" to 3"x60" in 1994? Even if you found an 8.75 (last used in 1974?) diff I think spring perches would be hurdle #1, then shock mounts and driveshaft, can't recall if it needs to be longer or shorter. There's nothing wrong with the 9.25", I'd keep it.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
