I was looking at the 16:1 box on firm feel with quick ratio idler and pitman arms.
Can you put the fast ratio power steering pitman arm onto a manual steering box? I never tried, I guess it hadn't occurred to me.
The fast ratio pitman changes a 16:1 box into a 12:1 ratio.
Here's the steering ratios on some modern vehicles to give you something to compare against.
2011 Challengers have a 14.4:1 steering ratio with 2.75 turns lock to lock
2014 Camaros have 16.1:1 ratio with 2.5 turns lock to lock
2015 Mustangs have a 16:1 ratio
1988 Mustangs have 15:1
Neon’s are 16:1.
Tav
