Originally Posted By BEINGmeISaCRIME
Has the intake plenum been checked? Its very common for those to blow the gasket and cause oil consumption.
If that is the issue, a functioning catalytic converter will burn up the oil and you will not see a leak on the ground.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
