I took a small ball(3/4") of aluminum foil wrapped tight. Tapped it in the heat cross over slowly until it conformed to the shape. Then used the RTV red to seal it in place.I used it together with the felpro gasket with the block off. Its been in 2 years with no problem. Sounds a little Mickey Mouse ,but it works!
