Just depends on where the priorities for the motor are.
If it's primarily a street car and the blower is mostly for "show", a 6-71 will work fine on that sized motor.
With a properly designed build, an easy streetable 600hp plus.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
