Originally Posted By DAYCLONA
Originally Posted By B5Cuda440-6
That's my fear as well...
I've found the ones from CarQuest pn# 8053015 (6 per box) are pretty much a match for OEM, the other repros on the market are often bright white nylon inserts in the spring steel cage, the carquest's are off white, more OEM looking, the cage and screw are OEM appearing
Why six per box? shruggy
