well i found a shop in my area and they recommended re-arching and an extra leaf. $125 each side.
next question would be (and i have searched it)i won't be able to use a standard B-body shock, right?
i have read that a C-body shock is the way to go, true?
just any 1969 C-body? i wouldn't think the actual shock length would be any different
$125 each side to re-arch? New stock spec springs are only about $150 a side.
I would suggest that you get the re-arched springs on and see how the shocks look before you decide. If they are too short, you can also use shock extenders and your current shocks.
