I have a 54 Dodge truck factory service manual. In there, everything electrical is tested by voltage drop. They allow .10 volt drop per connection. A .20 volt drop is excessive. The whole 6 volt system only has 46 amps available, according to the book.
Unfortunately, the Dodge truck starter in 54 was foot activated. You stepped on a pad above the gas to activate the starter. Gene
