Ron, About the torque converter, About a year ago i had an issue where something broke in the converter. It would squeal only during stall. Like idle, in gear, rear tires stopped. OR slow speed brake applied, Or a squeal between shifts. At the time not sure what it was. Asked a bunch of questions here. No real answers...
I figured it had to be the converter. I replaced it, problem solved. BUT, I tried to ask here what I should be using and people said I don't need anything special. When I ordered a new one they asked me If I wanted a "high stall" I didnt think so, so i ended up with a "LOW stall"
I don't know how low this is or how high the high is... It seems very tight. Did I get the right one????
Well you could have but it depends on what your combo is. Is your car all stock or is it built up some ? That will make a big difference as well as what gears are in it and the cars weight also just to start. Do you know what kind and stall was in it at all before ? Ron
