Quote: You would be better off to use a vac pump on the street... with a exhaust system it would have to be a VERY low restriction to allow a header vac to work
2" tti's w/3" tti x-pipe system and ultra flow mufflers.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
