Thumper
Better make sure you're equipped for a 9.99. They will toss you if you exceed your limit. That weekend should be choked with nostalgia cars prepping for the March Meet. If the weather holds it should be a fantastic weekend. If you are jetted for it this will be your fastest pass of the year. We probably won't see air this good after that until Oct/Nov in Bakersfield. Although track elevation is 300' it is common to race in 3000' plus. We will probably have early morning air in the 800-900 range which is awesome.
