Most everything with a serpentine belt system uses a reverse rotation fan and pump. The clutch is different too.
Yep..I've worked on alot of Chev C1500 trucks and they use a serpentine setup with a reverse rotation water pump/fan/fan clutch setup. (All the TBI ones, when they went to Vortec, they use a screw on fan clutch)
