jus got my 69 road runner back together from paint and rebuild.I have no spark in the sparkplug wires.I do have power in the points. I also have power in positve side of coil. i have power in the negative side of the the coil (not sure if thats normalL) i also have power in the single wire side of the ballast resistor. this is all when the key is turned on . Could it be a ground problem (new paint ) any help appreciated
