If I change over to solid FT from a solid roller.. how
much difference do I need to add to the FT to equal
the roller..I'm gong to a bit smaller cam then what the
roller is.. the roller is a 105lsa installed at 105..
260/270with .640/.640 with 1.5 rockers.. this is in a 416
so IF I change over to a FT how much more do I need to
go to come close to the roller... one thing that will
change is the LSA..I'm going to a 110lsa for the injection
so any help is welcomed.... I know the ramp rate will be
slower but if I go larger would it help..I would like stay
at about 260-265 duration and about .600-.630 lift
thanks guys
