Yes. No need to dismount. I like to remove the wheel/tire assembly from the car, but if you lift up on the car so you can rotate the tire/wheel to get to the hole, that would work too. Just follow the instructions in the kit and in a couple of minutes, you have a sealed tire if the hole is not too big.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
