In 71+ B bodies they use the E-body location for either shift; bench or non-bench.
If you had bucket seats you would have the shorter shifter.
I'm assuming this is the correct statement. So, there just is not two locations on the 72-74 models?
Incorrect statement, see my posts above showing all the components for both locations, the rearward location is approx in line with the end of the steering shaft where the steering wheel attaches, the BENCH SEAT location is approx 6" forward towards the dash from the end of the steering shaft spline where the steering wheel attaches
