None. All seem to have the same source or component parts.
Pick up is higher than stock as it doesn't sit parallel and close to tank floor. Runs out of gas with about 3-4 gallons fuel still in tank. Ratio is goof too with that short float arm. E and F occur at the appropriate times. What happens in between is comical.
