As said if power I would check the round nub clearance & if OK then I would clamp/or block off all 4 corners & see if the pedal is high an tight & if good then the prob is downstream & I would proceed to examining the corners by releasing LF then recheck then RF then recheck then rear. we gotta pin this down
